Question about the height of cowl gas tank
NY John T
Last Name: Killelea
Post by NY John T » Fri Feb 26, 2021 11:14 am
Hi all,
I have a 27 Tudor and the gas tank sits a little below the level of the top of the cowl. Is this correct? I've seen pictures of 26-27's with the cowl gas tank sitting up against the cowl. I can't get under the dash just yet to check it out. Any thoughts?
Thanks,
John
Re: Question about the height of cowl gas tank
Post by DanTreace » Fri Feb 26, 2021 11:33 am
The tank rides below the cowl, only close spot is the gutter that surrounds the gas cap, it directs spillage on the top of the tank to the ground.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Fri Feb 26, 2021 5:59 pm
I just installed mine and the top of the tank rests against two braces with webbing straps between. The height is determined by how thick the webbing is and how neat a job you did getting the webbing between the ribs on the braces. I did not take the time to cut the webbing as it is a little wide as it comes from the vendors. No big deal as mine sits about 1/16 low.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Fri Feb 26, 2021 6:01 pm
jiminbartow
Last Name: Patrick
Post by jiminbartow » Fri Feb 26, 2021 7:42 pm
Here are three pages from the Ford Service Bulletin Essentials book on how to install the “new” under cowl gas tank. Jim Patrick
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sat Feb 27, 2021 8:58 am
Also thrown in the mess is if you have the 27 model full cardboard pad that sits between the tank and firewall. This has some effect on how the tank sits . 26 has 2 webbing straps.
