Welding peddals
RichJ
First Name: Rich
Last Name: Jesteadt
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
Welding peddals
Post by RichJ » Mon Mar 01, 2021 2:11 pm
For you expert welders what is best rod to weld replacement peddals to activating? Arms? I'm using DC stick machine.
Thanks in advance
RichJ
First Name: Rich
Last Name: Jesteadt
Re: Welding peddals
Post by RichJ » Mon Mar 01, 2021 2:21 pm
I'm used 6013 don't like result
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Re: Welding peddals
Post by Herb Iffrig » Mon Mar 01, 2021 2:56 pm
I would have done the same. Others might have used 7018 rods
got10carz
Last Name: Meixner
Re: Welding peddals
Post by got10carz » Mon Mar 01, 2021 2:58 pm
7018 on DC. Slight preheat
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Welding peddals
Post by Dan McEachern » Mon Mar 01, 2021 3:25 pm
Just to add- cut the spliced area at a diagonal rather than 90 degrees to the length of the pedal shank as it will give you a much stronger joint.
RichJ
First Name: Rich
Last Name: Jesteadt
Re: Welding peddals
Post by RichJ » Mon Mar 01, 2021 7:05 pm
Dan
I've done as you advise
Do you think nirod would be stronger than 6013
Re: Welding peddals
Post by John kuehn » Mon Mar 01, 2021 7:16 pm
Use 1/8” 6011 rods. Run them around 90 amps. They will make you a smooth weld and better penetration than 6013.
Before you start to use your welder get you some scrap steel about the same thickness of the pedals and make some practice welds to set you welder to what’s suitable for you.
Some like to run a ‘hot weld’ using a little more speed than normal. That’s works OK if you are a experienced welder and know how to control your speed and heat. What ever you do practice a bit before you make the weld.
And do as Dan says to vee the joints a bit to give you a good weld.
Dan McEachern
First Name: DAN
Re: Welding peddals
Post by Dan McEachern » Mon Mar 01, 2021 7:25 pm
Veeing out the joint to get good penetration is also a good idea, but I was referring to running the actual joint itself at a diagonal in the direction from the shaft end of the pedal shank to the pedal tip.
Bob in ohio
First Name: Bob
Last Name: Gairing
Re: Welding peddals
Post by Bob in ohio » Mon Mar 01, 2021 10:16 pm
Last summer I wanted to install new peddle pads and was told about the difficulty welding the new shaft to the old ones. I welded one, it looked good then tested its strength. It broke like glass right at the weld interface. For safety purposes I decided to carefully cut the short shaft off the back of the new peddle and then cut off the original right and left side of the original pad. The new pad was then welded to the complete original peddle shaft. With a little hand fitting the peddle curvature before welding you can make it look just like original. If it should ever break off at least the peddles will still be functional to get back home.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Welding peddals
Post by Kevin Pharis » Mon Mar 01, 2021 10:34 pm
I’ve had good luck with stainless steel filler rod and TIG welding. Not sure how bout stick welding with stainless tho...?
John Warren
Last Name: Warren
Re: Welding peddals
Post by John Warren » Mon Mar 01, 2021 11:30 pm
I will second 7018 rod. I would use 3/32 @about 90 amps. I have used it very successfully. 7018 is a malleable rod and is a perfect match with the pedal material. 100% weld is easily obtained by chisel shaping the joints, like said making the joint at an angle will make the joints longer and stronger. Be sure and grind into the back side of your first pass to achieve 100% Also alternate sides as you build it out. Use a needle gun if you have one to stress relief it. If not chip it well and use a sanding disk to finish.
