Headlight issue
tommyleea
First Name: Tommy
Last Name: Russell
Headlight issue
Post by tommyleea » Tue Mar 23, 2021 10:09 pm
23T..Headlights keep blowing my fuse. It appears that the contacts that the harness connect to are tilted, and may be touching the socket housing, which I think is grounding out the harness, and causing the fuse to blow. If i disconnect the headlight harness from the headlights, the fuse is OK.. Is this a known problem that others have dealt with, and if so what is the fix. Are the contacts replaceable? Thanks..Tommy
John.Zibell
Last Name: Zibell
Re: Headlight issue
Post by John.Zibell » Wed Mar 24, 2021 10:11 am
Are you talking about the connector on the end of the harness or the part in the headlight itself? In either case both are replaceable. https://www.modeltford.com/item/6592X.aspx and https://www.modeltford.com/item/6574X.aspx If the sleeve in the headlight is bent, you should be able to straighten it.
1926 Tudor
tommyleea
First Name: Tommy
Last Name: Russell
Re: Headlight issue
Post by tommyleea » Wed Mar 24, 2021 10:16 am
The part in the headlight. Wow, I can't believe all the parts that are available. Thanks John..
