1926 Roadster Trunk Lock
Newtexaz
First Name: Randy
Last Name: Clemens
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup, 1926 Roadster, 1927 Fordor
Post by Newtexaz » Sun Mar 28, 2021 7:01 pm
Does anybody know how to deal with a inoperative trunk lock on a 26/27 Roadster? Cant get the trunk open..... I have tried all I can think of without causing damage.
Last Name: House
Re: 1926 Roadster Trunk Lock
Post by George House » Sun Mar 28, 2021 7:40 pm
I’ve removed the trunk lock on my ‘26 roadster by removing the 4 little screws. Otherwise I’d have to use the key to pull the trunk lid open after I unlock it. Now I just open it with the tips of 8 fingers. Don’t keep any valuables in the trunk anyway.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Mar 28, 2021 7:59 pm
Just press down hard when you inset the key and turn it counter clockwise.
You will surprise yourself!
Newtexaz
First Name: Randy
Last Name: Clemens
Post by Newtexaz » Sun Mar 28, 2021 9:56 pm
Thanks guys, tried the press down hard advice but it’s tight against the body....it has nowhere to go.
Post by RajoRacer » Sun Mar 28, 2021 9:59 pm
Did it work before and this a new problem ?
Bill Mullins
First Name: Bill
Last Name: Mullins
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Post by Bill Mullins » Sun Mar 28, 2021 10:42 pm
If the pin that guides the key is broken or loose I have used a 90 degree pick to trip the latch.
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by TFan » Sun Mar 28, 2021 11:02 pm
Sometimes if I'm feeling lazy and don't want to grab the keys I just grab the top of the spare tire and give it a tug to the rear while lifting upward on the deck lid. If this works for you then you can work on the latch, mine was froze solid with rust and I had to drill out the rivets that hold it together. If I remember correctly the screws go through the rivets. Good Luck Jim
Newtexaz
First Name: Randy
Last Name: Clemens
Post by Newtexaz » Mon Mar 29, 2021 8:30 am
Thanks everyone. I dont have a rear tire mount the car so nothing to pull on. I am thinking now I might have to go up through the battery opening and push with something - similar to pulling on the tire mount? This one has me puzzled.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Mon Mar 29, 2021 1:31 pm
The last lock I had that would not turn with a key, I worked it free with some transmission fluid by first dipping the key and then inserting into the lock.
Vern (Vieux Carre)
