Cellphone on 6volts
George N Lake Ozark
First Name: George P
Last Name: Clipner
Cellphone on 6volts
Post by George N Lake Ozark » Tue Apr 13, 2021 1:48 am
John.Zibell
Last Name: Zibell
Re: Cellphone on 6volts
Post by John.Zibell » Wed Apr 14, 2021 2:00 pm
Good thing the Model T is Negative ground so you don't have to reverse the polarity of the socket you put on the car. I have added a cigarette lighter socket to my T to power my Garmin.
1926 Tudor
dykker5502
First Name: Michael
Last Name: Deichmann
Post by dykker5502 » Wed Apr 14, 2021 4:12 pm
I've done the same in one of my T's and plan to do the same in the two others.
Ford Model T 1914 Touring
Post by Allan » Thu Apr 15, 2021 5:45 am
What kind of cell phone will not hold a day's charge? Mine is not that new, but it lasts me 2, sometimes 3 days before needing a charge at home.
Peter, Memphis TN
First Name: Peter
Last Name: Claverie
Post by Peter, Memphis TN » Thu Apr 15, 2021 10:22 am
Allan, the answer to your question lies not in the kind of cell phone, but in the circumstances of a Model T tour.
A cell phone, when it's just lying there or sitting in your pocket, is in constant communication with the closest tower. The stream of data going back and forth is automatic, and it's significant. You don't even know it's going on, until a message arrives and the human-interface portion of the phone is activated (the screen lights up and the bell rings).
When you're moving, each time you move from one tower to another tower the phone has to go through a complicated re-establishment routine. And, if you're in a place with no service or weak service, the phone "scrambles" to find service - sending out streams of "hellos." All this takes power!
As you can imagine, this is pretty easy for your phone when you're driving down an Interstate highway, with cell towers liberally sprinkled all along the route. That's what it was designed to do easily.
But, think of a Model T tour. You're on roads that have few towers, if any, and you're moving around. That means your phone is constantly searching for service, and often finds none. But it keeps searching. That takes the maximum amount of power the battery can put out. The very best you can ask for under those circumstances is very limited battery life.
There are two 'fixes' for this problem. One is to plug the phone in to a power source, as seen in this video. The other, simpler answer is to keep the phone turned OFF until you need it for some reason. This can give some folks the heeby-jeebies, because the idea of being without instant communication just doesn't feel safe these days. And of course, if you're using the phone as a GPS, you're taxing its capabilities to the max!
I hope this answers your question, though.
Post by Steve Jelf » Thu Apr 15, 2021 10:31 am
I wasn't sure my phone and Garmin would charge on six volts, so I installed 6-12 volt converters for those. It's nice to know I didn't have to do that. :)
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Thu Apr 15, 2021 12:15 pm
Using navigation or speedo app zaps the battery pretty fast on my phone. I think I may install a charger if it will charge on 6 volt. Momma will be happy to.
Post by Allan » Thu Apr 15, 2021 8:03 pm
Thank you Peter. My phone and I must live in a different world.
