Were these plugs used for military? or some other application ?
the 2nd is a timer part >>>>
thanks for the help, Bob
Identify these if you can plug and timer part
Re: Identify these if you can plug and timer part
I have a double contact plug with metal sheath, think it is how some were made by different manufactures. I was thinking timer ring was for a crystal timer, but guess not. http://www.mtfca.com/discus/messages/11 ... 1273895184
Topic author - Posts: 1697
- First Name: ROBERT
- Last Name: BERGSTADT
Someone told me military on the plug I think but not sure
The plug is typical Ediswan type, with the dual in-line nubs to twist and lock in the socket. Bayonet style.
These plugs could be had in rubber (plastic today) plug or metal banded.
The metal band holds up better, but cost more in the day. Used mostly for plugging to sockets for trouble lamps or dash lamps.
