Holley G parts Help
Caswell
First Name: Dean
Last Name: Brevit
Holley G parts Help
Post by Caswell » Tue Apr 27, 2021 9:52 am
Hi All, Does anyone know if the pickup tube and venturi clip are available anywhere, or can somebody let me know the size of tube used. I picked up a really clean carb in very good condition and the parts above are not in the carb. Thanks in advance .
Re: Holley G parts Help
Post by Mark Gregush » Tue Apr 27, 2021 1:24 pm
I think you are going to have to find a used tube. You will note that the bottom of the one shown, pickup end, is pinched partly shut. While you might be able to duplicate that with solder, getting the orifice and length the correct size might be iffy. Not to mention finding the correct size coupling nut and finding a flare tool that small and if you have the threaded piece it mounts to still with the carb.
You might try and contact Corey that sells the rebuilt carbs in the classifieds. He might have the parts. viewtopic.php?f=5&t=20727
And welcome to the forum. Good luck with your search.
