Is this where the fuze goes?
Mopar_man
Last Name: Govoni
Post by Mopar_man » Fri May 07, 2021 7:42 pm
So is this where the fuze goes? Yellow wire that comes from the battery side of the starter switch. Also can I go to my local hardware store and get rubber washers for each contact of the starter switch? Looks like there are two rubber washers for each stud.
First Name: Henry
Last Name: Lee
Re: Is this where the fuze goes?
Post by Henry K. Lee » Fri May 07, 2021 8:23 pm
Easier access Robert is where it comes to at the terminal block.
Last Name: van Ekeren
Post by Kerry » Fri May 07, 2021 8:47 pm
Fuze? :o unless you are going to blow up your T, I would use a fuse. :D :D
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri May 07, 2021 10:31 pm
Yes, that is one place to put it.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Fri May 07, 2021 10:47 pm
“It is a damn poor mind that can think of only one way to spell a word.” Andrew Jackson
Mopar_man
Last Name: Govoni
Post by Mopar_man » Fri May 07, 2021 10:52 pm
Thanks everyone!!!
Last Name: Hjortnaes
Post by DHort » Sat May 08, 2021 2:14 am
John Regan recommends the fuse goes close to the starter switch. Mine is inside the hood, closer to the terminal block like Hank states. I like the easier access there, and it keeps it out of any water or other debris under the car. Your choice.
Post by Kerry » Sat May 08, 2021 2:58 am
Robert, that could be true but only one way in spelling the word to mean "a circuit breaker"
Post by Allan » Sat May 08, 2021 4:47 am
Was Andrew Jackson a politician? Politicians are renowned for twisting language to suit themselves. We have different spellings to indicate different meanings. Sure, context can lead to the correct interpretation, but what is wrong with getting the spelling correct in the first instance?
Allan, ex grade school teacher, from down under.
Last Name: Hatch
Post by Dan Hatch » Sat May 08, 2021 5:36 am
Andrew Jackson, Indian fighter, Red Coat fighter and only US President EVER to pay off national debt and leave country in the black. Dan
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat May 08, 2021 6:10 am
Robert being a retired Marine.., me being retired Air Force.., we were talking in code! I was an Aircraft Weapons Technician and Avionics my fist hitch. Just flashbacks!
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sat May 08, 2021 10:31 am
True Being a Marine I work better with pictures. Ha!!
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Sat May 08, 2021 5:08 pm
I install My fuse at the firewall terminal block. like Henry K and Dhort did. another advantage is being able to easily disconnect electrical power to the car when You are working on the electrical system without doing the LIMBO Rock. " How low can U go"
If You want to fully fuse all the circuits on a model T. this is one way to do it. Not needed .but then looking at modern cars with fifty ? fuses. maybe they were on to something. They take no chances and fuse every electrical circuit in the car.
Fuse 2 Model T_resized (3).jpg (64.05 KiB) Viewed 3920 times
jiminbartow
Last Name: Patrick
Post by jiminbartow » Sun May 09, 2021 12:19 am
Mine is under the car close to the starter switch as recommended by John. Jim Patrick
Sarikatime
Last Name: Seress
Post by Sarikatime » Sun May 09, 2021 8:56 am
Why not just put in a kill switch and it will save you completely and it is a good anti theft device as well. Just a thought. Frank
Last Name: Wrenn
Post by TWrenn » Sun May 09, 2021 9:00 am
Both Jim & Franks suggestion are a good idea. I've also always said the fuse needs to be right at the starter switch, that way you have max protection. Its easier to install of course than a separate shut-off may be, since I'm basically lazy if I had to it'd be an inline fuse. Luckily my cars already came with them! :D
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sun May 09, 2021 12:21 pm
I do take the Neg wire off the battery of all my old cars when I'm not with them. Even at car shows. I like the idea of putting it close to the starter switch as possible. I'm still young enough to get under the car if there is a problem. I'm replacing all the wiring in the car and making everything "Bright and tight" as someone said in the forum.
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Sun May 09, 2021 2:03 pm
Why do you think a fuse will help?
Let’s say the motor is running and the fuse is located in the battery feed. Does mater if by the switch or hidden behind the firewall. Now you get a shirt to ground and the fuse blows. If the motor is running, the generator will still put out current and the car will continue to run 😊
So I repeat why a fuse it does nothing when the motor is running.
When the motor is not running, a cut off switch is much better protection.
If you really want fuse protection, one should be placed in each line like a modern vehicle.
Add a cut off switch.
Tony Bowker
La Mesa, California
Post by DanTreace » Sun May 09, 2021 2:28 pm
Add the fuse, better safety.
Once was driving down the road and smoke rolled out from under the dash!
Pulled over, shut down the T, and investigated.
Fat yellow wire at ammeter was frying!
A blown fuse would have stopped that smoke quicker than I did.
All my storage battery T’s have fuse in the Yellow batt wire going to the firewall terminal block.
Post by TRDxB2 » Sun May 09, 2021 3:39 pm
For Marines Semper Fiddling
Options
