Gypsy Curtain Patterns for a 26-27 Roadster
DontKnowMuch
Last Name: Sanford
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Post by DontKnowMuch » Sun May 16, 2021 11:57 am
Does anyone have a pattern for the Gypsy Curtains for a 1926-27 Roadster?
I found some good pictures on this forum but not a pattern with dimensions.
Mark Nunn
Last Name: Nunn
Re: Gypsy Curtain Patterns for a 26-27 Roadster
Post by Mark Nunn » Sun May 16, 2021 5:54 pm
...for me too, please. :)
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sun May 16, 2021 6:20 pm
If you can wait a couple weeks I have a set coming from Car. I would measure and post results unless someone beats me to it
DontKnowMuch
Last Name: Sanford
Post by DontKnowMuch » Mon May 17, 2021 10:21 am
Thanks for the offer. I will wait to hear from you.
Dennis
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sat May 22, 2021 5:21 pm
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sat May 22, 2021 5:23 pm
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sat May 22, 2021 5:25 pm
Let me know if you need anything else. I don’t know much as I just got them and haven’t even held them up to the car yet.
DontKnowMuch
Last Name: Sanford
Post by DontKnowMuch » Mon May 31, 2021 11:48 am
Thanks for posting these pictures. I did not see these until this morning. Can you measure one of the angles?? I am very rusty on my geometry.
Dennis
Post by TRDxB2 » Mon May 31, 2021 12:15 pm
Dennis
If you get the exact measurements of the inner triangle you can use this link to calculate the angles. Since the width of the each frame piece forms parallel lines the outer triangle would have the same angles. All the pictures with the tape measure need to be more accurate. https://www.calculator.net/triangle-cal ... &x=68&y=23
Here is an example:
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon May 31, 2021 3:34 pm
Make a template from cardboard first.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon May 31, 2021 8:25 pm
I will measure the angles as non are right angles to start with
