Rust Removal inside the 1927 Coupe Body
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Sun May 16, 2021 10:37 pm
The attached photo shows the floor under the seat inside my couple. It will be blasted cleaned. However, there are small seams near the front vertical part of the seat support. The blast cleaning will not remove rust in the seams. There are other small crevices at various places in the floor. I am thinking of putting some "Krud Kutter Must for Rust" in these seams and crevices and letting it soak and dry. Anybody see an problems with that procedure?
dejaolsone
First Name: dejaol
Last Name: sone
Re: Rust Removal inside the 1927 Coupe Body
Post by dejaolsone » Mon May 17, 2021 2:27 am
Take the time to enjoy the impossible quiz online
Post by TXGOAT2 » Mon May 17, 2021 12:17 pm
Will it stop needless barking and controil most household pests for only 19.95 per month?/
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Mon May 17, 2021 3:36 pm
What are those two responses????????????
Post by Jerry VanOoteghem » Mon May 17, 2021 4:18 pm
They're called Spam..
To answer your question, I would clean up all that I can, then paint with Rustoleum rusty metal primer, followed by Rustoleum flat black.
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Mon May 17, 2021 9:18 pm
OH!! Thanks, What do think of my idea to put krud Kutter in the seams and crevices?
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon May 17, 2021 9:25 pm
Clean by vacuuming well, on a warm day, low humidity, give multiple light coats. Done!
Hope this Helps,
Last Name: Tannehill
Post by JTT3 » Mon May 17, 2021 10:07 pm
You could use a product called evaporust found at harbor freight Walmart and other like stores even on Amazon. I have used it with a small electric pump with a hose that sprays the liquid on the area and another hose for the pump to suck the liquid up. I used a large bucket to catch the sprayed evaporust that concentrated the liquid on the area that was rusty Worked like a charm in about 5 hours of me doing nothing but checking on the progress. I’ve also used it to clean out heads and blocks using the same technique, great product.
