Repurposing Model T Parts
Post by TRDxB2 » Sun May 23, 2021 11:14 am
Some pictures are of Model T parts and other contain parts similar to T, so you can get the idea. The idea is to use worn disfunctional parts modified to work the idea. This link has has some really neat ideas http://fordiyers.com/ways-to-repurpose-old-car-parts/
Old worn dull reflectors -
could replace rivets with hook eyes for coats, hats , keys etc
Could used split rim tool , cam shaft
Re: Repurposing Model T Parts
Post by TRDxB2 » Sun May 23, 2021 11:17 am
More ideas for them
Post by Mark Gregush » Sun May 23, 2021 11:19 am
I have some 26 head lights that was thinking about adding socket and mounting plates to make outside wall lights. They are too far gone to use on cars but have nice patina for rustic look!
Post by RajoRacer » Sun May 23, 2021 11:34 am
I utilized some old T running boards for my accessory collection shelves - figured it was a fitting retirement place !
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Sun May 23, 2021 11:35 am
Years ago my uncle used old model T driveshafts for horseshoe pegs. :D
Post by TRDxB2 » Sun May 23, 2021 12:11 pm
And there's more
Last Name: Wrenn
Post by TWrenn » Sun May 23, 2021 12:15 pm
Think I like the chandelier the most!
Last Name: Hjortnaes
Post by DHort » Sun May 23, 2021 6:11 pm
the sink on the right. Is that for dipping parts in so they do not rust?
Lot of nice idea's out there. Like
CraneJon
First Name: jon
Last Name: crane
* REQUIRED* Type and Year of Model Ts owned: 1925 T pickup, 1928 A, 1931 A
Post by CraneJon » Sun May 23, 2021 8:28 pm
I once heard about a Montana Gunsmith who made damascus shotgun barrels out of Model T rear axles I asked Stan Howe about it and he did not know the gunsmith.
A local cider mill in Michigan has a press made from T Parts.
I have a friend who is making a pumping and operating windmill from T parts. Tower is four rails ot the frame.
Jon
Mighty1924
First Name: Rick
Last Name: Shaw
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring. 1924 Coupe
Post by Mighty1924 » Sun May 23, 2021 8:48 pm
Here is a couple of projects from T Parts
Lots of time last year too make things.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Wed May 26, 2021 6:18 pm
I went to help a friend put a 300 straight 6 to power an irrigation pump on this old trailer he had and it was obvious how it’s life began. It has the holes for the early running board brackets. His trailer for a welding machine is a T frame as well.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Wed May 26, 2021 7:56 pm
Post by TRDxB2 » Wed May 26, 2021 8:11 pm
Forgot I did this. Old axle shaft used as an anvil for peening. Used on break lever cam & slow speed notch
Post by Wayne Sheldon » Thu May 27, 2021 3:52 am
Must be something wrong with me? I keep fixing parts others threw away and using them on my cars.
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Thu May 27, 2021 7:42 am
Some of my work (www.greenfancompany.com) Enjoy
Dennis Fleming
Last Name: Fleming
* REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
Post by Dennis Fleming » Thu May 27, 2021 1:15 pm
My engine stand
Post by TRDxB2 » Thu May 27, 2021 2:12 pm
Chassis engine stand (I didn't do the stand and had to give it back) :oops: . Tilt front back to roll on wheels
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Thu May 27, 2021 5:21 pm
I'm about to make a cart for a gas welder out of a Model T frame. The frame was butchered in the past and is not suitable to be used for a car.
1924 Touring
