Gas pump nozzle clip?
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed May 26, 2021 3:48 pm
For those of you that live in areas with vapor recovery boot of gas pumps, you'll know what I am talking about.
I filled up one day and the guy handed me his "gas clip" out of his back pocket. It was made out of aluminum and it held back the boot that otherwide needs to be held with your hand while filling the gas tank. Otherwise it will shut off after you put about 2 gallons in...
I know motorcycle guys would appreciate one of these, too.
Anyone know where I can find one, or have dimensions so I can fabricate one?
Thanks,
Keith
Re: Gas pump nozzle clip?
Post by Norman Kling » Wed May 26, 2021 4:32 pm
That would be especially useful in filling a 26-27 or a Model A.
George Mills
Last Name: Mills
Post by George Mills » Wed May 26, 2021 4:58 pm
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed May 26, 2021 5:23 pm
I already checked with them. They are out of stock until late June...
Post by TRDxB2 » Wed May 26, 2021 8:58 pm
Should be easy to make
Found this : Nozzle size standard dictates that the delivery nozzles for unleaded fuel shall not exceed 0.85" in diameter while the delivery nozzles for leaded fuel shall not be less than 0.93" in diameter.. However if the bellows are and EVR type ( Enhanced Vapor Recovery) the pad needs rest flat enough to cause a suction.
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Wed May 26, 2021 9:36 pm
Should be a snap to build as many as You want with a 3-D printer.
Last Name: Wrenn
Post by TWrenn » Thu May 27, 2021 8:55 am
Fab one from plexiglass or lexan. Can't be that hard to do.
Post by Original Smith » Thu May 27, 2021 10:31 am
I've been using my left hand for years with no problems!
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Thu May 27, 2021 10:34 am
I think that is an inappropriate remark Larry, this is a family show :lol: :lol:
Leo van Stirum, Netherlands
