If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
- First Name: Tom
- Last Name: Rootlieb
Post
by Dollisdad » Sun Jun 06, 2021 12:51 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 12:52 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 12:53 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 12:55 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 12:56 pm
- First Name: Tom
Post
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 12:57 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 12:58 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 12:59 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 1:00 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 1:01 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 1:02 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 1:03 pm
- First Name: Tom
Post
by Dollisdad » Sun Jun 06, 2021 1:04 pm
Post
by TXGOAT2 » Sun Jun 06, 2021 1:34 pm
I'd bet that fellow with the ballerina lamp mounted on his hood had a leg lamp prominently displayed in the front parlor window at home.
Post
by TXGOAT2 » Sun Jun 06, 2021 1:45 pm
Re: T in front of "standard" oil derrick: When I was a kid, there were 4 of those rigs within 600 to 1500 feet of the house. A fifth well had a steel derrick, but retained the standard rig front. Two of the outfits were operational and pumping oil. One was powered by a Bessemer 25/30 HP single cylinder, 2 cycle gas engine, and the other was powered by a 35 HP Superior single cylinder 4 cycle engine. The other three were operated from a single 35 HP Superior single cylinder gas engine using pull rods laid along the ground to power underpull steel pump jacks sitting on the rig floors at the locations. I still have the powerhouse engine, and it still runs. The whole property was a mechanical wonderland.
