Year and value?
tirekicker
Topic author - Posts: 5
- First Name: Sean
- Last Name: Heywood
- * REQUIRED* Type and Year of Model Ts owned: 1924 project
Year and value?
Hi guys, I am curious as to what year this is and what the value of it may be. Thank you.
- Last Name: Tannehill
- Board Member Since: 2002
Re: Year and value?
23-25, max to me about $400
Re: Year and value?
Remains of a '25. Equal length front door hinge. Wide bead front fenders. Stuck engine, crank is up and locked!
Same value. A few hundred.
- Last Name: House
Re: Year and value?
Concur ‘25. Only value is $350 engine for a core.
Re: Year and value?
No more than $400.00. Radiator shell may be good enough to clean up and use along with the cowl, maybe. The engine may not be cracked. T’s have been built up with parts like these and turned out pretty good but as the old saying goes “one mans trash is another mans treasure”.
