Question - Valve Stem Lubrication on Open Valve Engines
Last Name: Strange
Post by CudaMan » Thu Jun 24, 2021 10:24 am
Not strictly Model T, but related - My 1912 Flanders engine has an open valvetrain. How much and how often do the folks with Model Ts with open valvetrains lube their valve stems? Do you use the same oil as what's in the sump, or something thicker, like 600W? Thanks! :)
Darren J Wallace
First Name: Darren
Last Name: Wallace
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian Touring 1905 Queen model B
Re: Question - Valve Stem Lubrication on Open Valve Engines
Post by Darren J Wallace » Thu Jun 24, 2021 10:53 am
I have a 2 cylinder Queen with open valves that don’t benefit from any crank case oil. I spray them with an Amsoil product specifically for motorcycle chains. Amsoil Chain Lube. I use it on the car’s chain too. It doesn’t attract dirt or dust and lasts a long time.
Post by Mark Gregush » Thu Jun 24, 2021 11:58 am
Good question! If you think about the early fuels, the valve stems might have gotten their lubrication from the fuel, but with today's drier fuels, wouldn't something like an upper lube help? ( LOL no I am not going to say the brand!) The lifters on the Model T would get their lube the same way as normal, the hole was added to the closed valve chamber to let the oil drain back down. Doesn't the Queen have a flat engine, so may have different requirements for oiling the valve train.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Thu Jun 24, 2021 2:52 pm
Marvel Mystery oil in the gas tank will lube vale stems as well as/or a pint of engine oil in a full tank of gas.
