First New Vane Actuators Fresh off the Assembly Line
MKossor
Last Name: Kossor
Post by MKossor » Fri Jul 02, 2021 2:19 pm
Just inspected the first samples of the Vane Actuators from a new run. The workmanship, quality and machining tolerances are all excellent with window edge to window edge machining tolerances well within the specified +/- 1 degree tolerance. This is very important because it determines the cylinder to cylinder ignition timing accuracy and consistency.
Mechanical tolerances were verified by electrical performance test using the E-Timer and its specially designed test set. Cylinder to cylinder timing error is less than +/- 0.4 degrees. Note that Automatic Timing Advance remains active and accurate from 400 RPM to 3500 RPM during this timing accuracy test operating on 12VDC battery.
Please pass this information along to other interested parties. I am prohibited from posting this accomplishment on the discussion forum being the vendor who designed, developed and markets this item.
Re: First New Vane Actuators Fresh off the Assembly Line
Post by TXGOAT2 » Sat Jul 03, 2021 4:27 pm
That's probably more accurate than the piston timing at most speeds and loads.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Jul 07, 2021 6:40 am
E-Timer running on 12 Volts? I thought the E-Timer was built for 6 V only. I just installed an E-Timer but have not driven my car beyond my driveway yet. I use a 6 V battery.
MKossor
Last Name: Kossor
Post by MKossor » Thu Jul 08, 2021 12:25 am
The E-Timer was designed to operate on 6V, 8V, 10V or 12V battery. The computer monitors the operating voltage and adjusts coil timing for optimal performance automatically.
Post by Scott_Conger » Sat Aug 14, 2021 10:33 pm
worthy of a bump
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Thu Sep 16, 2021 5:48 pm
I do not understand what this part does. Does it make the E-Timer work better? I'm curious because both of my cars have E-timers.
Paul
JWalters
First Name: Jason
Last Name: Walters
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by JWalters » Wed Sep 29, 2021 6:26 pm
Bump to top
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
Post by FreighTer Jim » Sat Oct 09, 2021 6:29 pm
Bump ….
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
