Stromberg RF adjustment
Bruce Compton
Topic author - Posts: 670
- First Name: Bruce
- Last Name: Compton
Does anyone have info on adjusting the economizer arm on a Stromberg RF carb? It's run from a cam on the throttle shaft similar to the one on an OF but the RF cam does not have a slope and just runs parallel to the rollers on the arm. It's supposed to richen the mix as the throttle opens but the position stays the same as the cam is flat. Thanks in advance. Bruce
- First Name: Henry
- Last Name: Lee
Re: Stromberg RF adjustment
Let me look in my very old manuals Bruce!!!!!
- First Name: Henry
- Last Name: Lee
Could only find info on “O” and “M” series, sorry!
see if you cannot find evidence of this "bump" in your cam which someone has apparently fixed for you...
Bruce Compton
- First Name: Bruce
Thanks Henry and Scott. My cam has the hump as shown but I was questioning the additional adjustment on the economizer arm itself that apparently changes the angle or approach of the rollers to the cam. I have 5 different economizer arms and they all have slightly different positions for this adjustment. I also have the Stromberg factory "book" for these "Airplane" carbs and there is no mention of this adjustment.
BuddyTheRoadster
- First Name: Chris
- Last Name: Rini
- * REQUIRED* Type and Year of Model Ts owned: 1923 roadster
I may have something. Give me a day or two and I will email you.
