This manifold came with the 1917 two piece crankschaft engine.
Does any know where it was used??
I had one before but it was cracked, this one is in fine condition.
Andre
Belgium
exhaust manifold
AndreFordT
Topic author - Posts: 565
- First Name: Andre
- Last Name: Valkenaers
Ruxstel24
- Last Name: Hanlon
Re: exhaust manifold
Andre, that is a manifold for a heater.
All the little dimples are screws for a shroud that goes over it and directs hot air to the floorboard.
I have one too, with no shroud the same as yours.
That's correct. It is for a heater. If you use a heater, be sure there are no exhaust leaks or you could bet carbon monoxide poisoning.
Some pictures of it in use
- Attachments
- Heat King on Arvin.jpg (45.05 KiB) Viewed 1321 times
- 380532.jpg (23.34 KiB) Viewed 1321 times
AndreFordT
- First Name: Andre
Thanks All,
Great information.
Andre
Belgium
Great information.
Andre
Belgium
