Radiator cap spinning while driving.
Sarikatime
Last Name: Seress
Post by Sarikatime » Wed Jul 14, 2021 9:42 am
I drove the 12 over to a friends house and while driving I noticed the dogbone radiator cap with the motometer started spinning. It was un screwing. I put in a new rubber gasket from Lang’s and it was nice and tight but it started unscrewing by itself again while driving. It is a original round tube radiator and old cap that is not all worn out with new rubber gasket, the cap threads are tight as I screw it on the radiator, what am I not seeing. Frank
John Codman
Last Name: Codman
Re: Radiator cap spinning while driving.
Post by John Codman » Wed Jul 14, 2021 9:48 am
You could move South of the equator; the Coriolis effect would then cause the cap to tighten.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Wed Jul 14, 2021 9:59 am
Try a leather or fiber gasket ?
What you are seeing is how much the motion and vibration is acting on the filler neck with the weight of the dog bone cap and motometer.
Last edited by Rich Bingham on Wed Jul 14, 2021 10:01 am, edited 2 times in total.
"Get a horse !"
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Wed Jul 14, 2021 10:01 am
Those dog bone radiator caps are not beneficial on brass cars that are driven, they often cause unneeded vibration and stress due to weight imbalance that will cause cracks and leaks in the solder at the base of the radiator neck.
paulgriesse
First Name: paul
Last Name: griesse
* REQUIRED* Type and Year of Model Ts owned: 1924 touring 1912 touring
Board Member Since: 2003
Post by paulgriesse » Wed Jul 14, 2021 10:12 am
Frank---I had a similar problem on my `24 Touring---replaced the std. rad gasket with a large o-ring--this allowed better tightening and now keeps my dog-bone rad cap firmly in place---good luck! paul
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Wed Jul 14, 2021 10:17 am
I have experienced caps bottoming out on the threads before contacting the gasket. Remedied by adding one or two more gaskets. I believe it would make a more snug fit.
Post by Norman Kling » Wed Jul 14, 2021 11:25 am
At any hardware store you can purchase a sink drain gasket, made for a bathroom sink. These will fit into the neck and are soft enough that you can tighten the cap to the desired position. In my experience with the dog bone or wing type cap, they stay in place when driving.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Wed Jul 14, 2021 12:31 pm
:lol: sorry, but that is funny
Sarikatime
Last Name: Seress
Post by Sarikatime » Wed Jul 14, 2021 2:54 pm
Well, I am not planning on moving to south of the equator, but, I am going to try some pipe dope or pipe thread compound. It seems to work really well sealing dripping oil where I used Teflon tape before. All ideas welcome. Frank
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Wed Jul 14, 2021 3:05 pm
John Codman- thanks for that! I laughed out loud at work!
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Post by FundyTides » Wed Jul 14, 2021 3:15 pm
Maybe the "arms" on the dog bone need to be balanced :lol:
John Heaman
Last Name: Heaman
Post by John Heaman » Wed Jul 14, 2021 3:23 pm
By the picture you submitted, you seem to drive at precarious angles. :lol:
Sincere question: Do the dog bones and wings cause the separation problem on the riveted 1913 radiator filler necks to the tank?
Post by Steve Jelf » Wed Jul 14, 2021 3:34 pm
No motometer needed. :)
Last Name: Wrenn
Post by TWrenn » Wed Jul 14, 2021 3:39 pm
One fiber gasket at the bottom, then the neoprene, followed by pipe tape worked for me.
On my Fordor I had the motometer NUT come loose and disappear into the rad tank! A club friend had a new nut that fit.
John Heaman
Last Name: Heaman
Post by John Heaman » Wed Jul 14, 2021 3:50 pm
I heard getting the rad tight solves the problem!
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Wed Jul 14, 2021 4:42 pm
A refresher on radiator cap installation is required here I’m afraid.
Luke
First Name: Luke
Last Name: P
* REQUIRED* Type and Year of Model Ts owned: 1926
Post by Luke » Wed Jul 14, 2021 4:43 pm
Confirming, per John Codman's information, that 'down under' we don't have an issue with the cap unscrewing during use.
However we have some difficulty checking the level 'cos the water just falls out when we do take the cap off... :mrgreen:
Last Name: Hjortnaes
Post by DHort » Wed Jul 14, 2021 5:19 pm
Many of you know Dean Yoder drove from Richmond, IN to Spokane. I am not sure if he lost his cap, but he replaced it with what looks like a Gatorade bottle upside down. He has driven with that replacement for at least a thousand miles.
It works
John Heaman
Last Name: Heaman
Post by John Heaman » Wed Jul 14, 2021 6:17 pm
I have a friend with a vintage Rolls Royce and when he goes to an informal car show or cruise-in, he removes the 'flying lady' (Spirit of Ecstasy) mascot and puts this in it's place. I don't have an actual picture of his car and the ornament so I grabbed a stock picture from the World Wide Interweb.
He duct taped a wooden plug to the bottom of it and plunks it in the filler neck.
His theory is if someone wants to steal Snoopy and his biplane, then have at it!
Post by Steve Jelf » Thu Jul 15, 2021 12:13 am
I was lucky that it just turned over and didn't fall off before I noticed it had worked loose. I do make sure it's screwed down tight now.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Thu Jul 15, 2021 6:27 am
The strangest parts often work themselves loose on a T. If you haven’t lost something while driving a T, you are in the minority I would guess.
Last Name: Seth
Post by perry kete » Thu Jul 15, 2021 9:28 am
The radiator cap becomes loose or spins off because you are using the wrong motor oil! :shock:
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Thu Jul 15, 2021 9:31 pm
A couple flat rubber gasgets from the plumbing dept. In the hardware fixed mine. Before that I had to drive in reverse to keep it tight.😁
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Sun Jul 18, 2021 5:51 am
Frank, when you tighten down the cap with the rubber gasket, can you feel it "snug" down on the gasket nice and tight? I have used one of those rubber gaskets from Lang's for years with my dogbone cap with MotoMeter on our '25 coupe and on the TT that Dallas now has with absolutely no problems. Granted, that's not the same neck as yours, but I don't see how your cap could loosen that easily if it is contacting the rubber nice and snug. As was said, an extra 'O' Ring might be worth a try. I did have the MotoMeter nut loosen up once, but I caught it before it fell into the radiator. Dave
1925 mostly original coupe.
kelly mt
Last Name: Kelly
Post by kelly mt » Mon Jul 19, 2021 12:50 pm
I've lost two Motometers now so I don't run them anymore. The cap, Motometer and neck all left on their own. Running dirt roads just makes it happen faster. The replacement pictured worked well, no vibration.
Post by Steve Jelf » Mon Jul 19, 2021 1:40 pm
Video still showing Dean's current motometer. :D
