Balance Beads - Wooden Wheels
Topic author - Posts: 225
- First Name: Bryan
- Last Name: Tutton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Model T
I have a 1914 Touring with clincher wooden wheels that I am almost finished restoring. It is sitting on jacks with all 4 wheels in the air and the wheels are nice and round and straight, but seem out of balance. Besides being wooden wheels I am using the heavy brass valve stems and brass dust covers so I would expect them to be out of balance. I have new tires, flaps, tubes and have even replaced the bearings and seals because I would like to run the car 35-40MPH for short bursts when needed. How much of a wheel balance problem do you think I will have? I have read that balance beads can balance any Model T wheel.
What the general opinion about balance beads in wooden clincher tires with brass stems and brass dust covers?
- First Name: Joseph
- Last Name: M
Re: Balance Beads - Wooden Wheels
I have Dyna-Beads in all 4 tires and there is a noticeable difference.
Dyna-Beads are one of the few products in life that usually deliver more than expected. They are a very good enhancement for a typically unbalanced T wheel.
- First Name: Ralph
- Last Name: Fitz-Gerald
I have them in my 15 touring car for the last 4-5 years and they real have improve drive ability.
- Last Name: Juhl
I have 6 oz of Counteract balancing beads in each of my tires. I notice absolutely zero out-of-balance indications while driving - across all speed ranges. The fun part is introducing the beads into the tubes. I attached a plastic hose to a condiment bottle and slip the other end over the valve stem (held in place by a small hose clamp). It requires patience..... if you have trouble getting the beads to flow smoothly I've found that vibrating the valve stem with an electric engraving tool will help.
- Last Name: Hunter
- Board Member Since: 2002
I've had balancing beads for about the last 10 years. I only noticed their effect at high speed. Getting them into the tube requires patience, not to try and pour them in too quickly or the tyre valve blocks up.
- Last Name: M
A recurring theme I agree with. Definitely bring your patience when attempting to put them in. Instead of an engraving tool as mentioned above, I used a Dremel tool to provide the vibration to help them down the tube and into the stem.
