'14 headlights
sweet23
First Name: Darryl
Last Name: Bobzin
'14 headlights
Post by sweet23 » Fri Aug 06, 2021 12:47 pm
A '14 touring car followed me home. I have a question concerning the headlights. Were any of these made without the model number ? Was the 666 number removed from these ? Or are these reproduction ? Yes, I know the lenses are incorrect. They had been converted to electric lights. Thankfully, I only need plain lenses and burner forks to return them to gas lights. And while I am asking, is there anything special about the lenses ? Are they just plate glass ? Thank you for your input, Darryl
Last Name: Hatch
Re: '14 headlights
Post by Dan Hatch » Fri Aug 06, 2021 3:17 pm
Darryl: Those look like E&J lights for a 13/14. Me thinks 666 are all brass. 13/15 were a different light, iron and brass like what you have.
Get Bruce’s book and you will many answers to T questions.
Please show the lens, you may have some accy lens. Dan
sweet23
First Name: Darryl
Last Name: Bobzin
Re: '14 headlights
Post by sweet23 » Fri Aug 06, 2021 4:26 pm
Dan, I have the book. The lights look like model #666 and or #66, just wondering why there is no number on the light. There is no mention of unmarked lights in the article. They are gas lights that had been converted to electric. Lucky for me is who ever did it, made it possible to return them back to gas lights. Just wondering if anyone can shed some light on what I have here, or if anyone has seen unmarked lights.
Last Name: Hatch
Re: '14 headlights
Post by Dan Hatch » Fri Aug 06, 2021 4:51 pm
I think I read somewhere that the 13/14 E&J lights they just left the 666 off the chimney.
Also body is same as 666 just made out of steel instead of brass.
Dan
sweet23
First Name: Darryl
Last Name: Bobzin
Re: '14 headlights
Post by sweet23 » Fri Aug 06, 2021 5:03 pm
There is little info in Bruce's book, Ray Miller's book has a chapter on lights, but the photos are not clear, and no mention of lights not having model number.
pre15dale
First Name: Dale
Last Name: Kemmerer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Re: '14 headlights
Post by pre15dale » Fri Aug 06, 2021 8:00 pm
The E&J lights for 13&14most had the number 66, or656 and som had no number. I have examples of all three
sweet23
First Name: Darryl
Last Name: Bobzin
Re: '14 headlights
Post by sweet23 » Fri Aug 06, 2021 8:20 pm
Dale, that is helpful information. I just saw a pair on E-Bay with no model number. My fear is that they were reproduction, or had been messed with. I will carry on. Darryl
Last Name: Wrenn
Re: '14 headlights
Post by TWrenn » Fri Aug 06, 2021 8:37 pm
My '13 has E & J with no number. And from
what I've heard, there were no reproduction headlamps made past 1912. Maybe someone else knows better.
Last Name: Wrenn
Re: '14 headlights
Post by TWrenn » Fri Aug 06, 2021 8:39 pm
Re repros not being made past 1912, I failed to mention I meant in the brass era. Pretty sure the black lamps have repros.
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Re: '14 headlights
Post by Marty Bufalini » Sun Aug 08, 2021 5:44 pm
My 1914 touring E&J headlamps also have no number and the car is all original. Research shows that is not unusual.
Re: '14 headlights
Post by Allan » Sun Aug 08, 2021 8:19 pm
My understanding is the all brass lamps were numbered with model 666. When the black and brass lamps were introduced, one of the sixes was deleted and the model number 66 was off centre, due to the third six being deleted.
That doesn't helps with no model number lights, but I do not believe yours are reproductions. The repops I have seen have the details on the brass chimney engraved/etched into the metal. Genuine articles are stamped with a die, and this results in narrower lines and depressions around the details, as your lamps show.
sweet23
First Name: Darryl
Last Name: Bobzin
Re: '14 headlights
Post by sweet23 » Sun Aug 08, 2021 9:14 pm
Thanks to everyone that replied. I am calling them good. Everything else on this car seems to be original & correct except for the carburetor. I would have found it hard to believe that the lights were not originals. Darryl
