Tail Light Model 25P
ryanf1023
First Name: Ryan
Last Name: Fenrich
* REQUIRED* Type and Year of Model Ts owned: Speedster Project
Post by ryanf1023 » Tue Aug 17, 2021 7:37 pm
I got this tail light from a box of miscellaneous parts from the major donor to my Model T project. I’m guessing there is a clear lens that goes here. Any input? I’m planning to use this as a brake light (perhaps LED) as I have an oil lamp as my tail light.
sweet23
First Name: Darryl
Last Name: Bobzin
Re: Tail Light Model 25P
Post by sweet23 » Tue Aug 17, 2021 7:40 pm
it is just a clear plastic lens that fits inside. It is available from the vendors
Post by DanTreace » Tue Aug 17, 2021 10:04 pm
Or just make your own clear lens for the license plate illumination.
A clear plastic bottle has just the right curve on the sides, a sharp pair of scissors, and quickly you have a slip in lens. The curve plastic trimmed to length to fit the tabs in the cup. Trim length just right and the tension holds your new replacement lens just like factory. :D
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Tue Aug 17, 2021 11:34 pm
If you are planning on using this one as a brake light, then you should block this window with metal or if you use a lens, paint it black. The side facing window is intended to provide constant light for your license plate from the tail light. If you leave it clear, you will get a bright light shining wherever you point the window every time that you apply the brakes. At best, it will look weird, or worse, confusing or distracting to the driver behind you. The vendors sell a version of this light without the side window that is more appropriate for brake lights.
Keep crankin’
Eric
Post by Steve Jelf » Wed Aug 18, 2021 12:54 am
I recently adapted a couple of similar lights I intend to use for brake/tail lights. I filled the side openings with pieces of can and covered them with body solder. I haven't done enough of that kind of work to be good at it, but I think they turned out OK for a first attempt.
Post by Allan » Wed Aug 18, 2021 1:06 am
I use a pair of them for brake and tail lights. Your US lights make a matching pair with our RHD lights. Dan's side window treatment is the easy answer to filling the number plate hole. Leaving it clear is of no real consequence. To use them as brake and tail lights, you need to fit a pair of double contact headlight sockets. The white paint in the interior makes them much more visible through the typically dark original lenses.
Post by DanTreace » Wed Aug 18, 2021 8:34 am
As Allan posted, using the clear plastic fabricated lens for the opening. When you spray paint the inside of the lamp housing white for best illumination, that blanks out and makes the clear opaque, so no wrecking a good rear lamp for the purpose of making a stop lamp!
Post by Steve Jelf » Wed Aug 18, 2021 9:02 am
...no wrecking a good rear lamp for the purpose of making a stop lamp!
No wrecking involved. Solder melts. The patch can be removed easily enough. :)
Post by DanTreace » Wed Aug 18, 2021 1:16 pm
Steve
Just poking fun at your solution, actually you did a splendid job! Too Good!
In fact, years from now someone will come upon your Ford tail lamp housing and declare it a "rare" factory error.....no license light opening :lol:
ryanf1023
First Name: Ryan
Last Name: Fenrich
Post by ryanf1023 » Wed Aug 18, 2021 1:21 pm
I appreciate the replies, thank you.
Interesting approach Steve. Perhaps I’ll try the same.
