Outer Muffler Shell
Dennis_Brown
Last Name: Brown
Outer Muffler Shell
Post by Dennis_Brown » Mon Sep 20, 2021 10:43 pm
I did some measuring several years ago but can't remember. Will a 5 inch truck exhaust pipe fit inside the ends for a T muffler? It would definitly be thicker than the stove pipe metal that was on most mufflers.
Kuhner
First Name: Greg
Last Name: Kuhnash
* REQUIRED* Type and Year of Model Ts owned: 1917, 1921 touring 1927 RPU
Board Member Since: 2006
Re: Outer Muffler Shell
Post by Kuhner » Tue Sep 21, 2021 7:54 am
Yes it works very well.
I used the pressed still ends but I think the cast ends would work better.
“I don’t like nice people. I like tough, honest people”. - Woody Hayes
Farmer J
Last Name: Kramer
* REQUIRED* Type and Year of Model Ts owned: 3
Post by Farmer J » Tue Sep 21, 2021 8:49 am
I have repaired several blown out mufflers that way
Post by Mark Gregush » Tue Sep 21, 2021 12:13 pm
Cast type ends; There is a taper to the ridge the outer shell fits onto. When the muffler is assembled and through bolt is pulled up, the ends of the outer tube get slightly flared to seal. The minimum OD on the cast ends is about 5" at the end and approx 5-3/16" at the bottom, so ID on the 5" pipe would be too small.
