Greetings all!
Am requesting information on firestone split rims. What I need is the dimensions of the clasp which holds rim together. It is two pieces, one is a rectangle and the other is an arrow which pivots on a pin.
Thamks,
John.
firestone split rim
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: firestone split rim
This should help you out. Play with your printer scale to get the ruler to measure right and you will have a full scale template.
Topic author - Posts: 138
- Last Name: hardiman
- * REQUIRED* Type and Year of Model Ts owned: 26 coupe
I don"t know how to do that. But, will give it a whirl.
John.
John.
No way, printer scale! Can't get it done. Any others have a thought?
Scale it manually. Put a measuring device to the ruler shown. Do some division for a conversion ratio. On my monitor the 2" ruler is 2.050" Near enough 1 to 1. So the bar is about 2 3/3 long. The lock is just under 1.75" long
I'm a genius! John and Jeff much appreciated. Many thanks.
