Simmons intake manifold...A or T ?
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Tue Sep 28, 2021 8:30 pm
Found this manifold mixed in with an A heater manifold. It lines up with the ports on a T block.
Looks like a zoom zoom updraft carburetor would fit.
Re: Simmons intake manifold...A or T ?
Post by Wayne Sheldon » Tue Sep 28, 2021 8:43 pm
That is a model A version. However, the spacing is right. And with a little effort it could be used on a model T!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Sep 28, 2021 8:46 pm
Sure looks model A to me. The port flange shape and the exhaust manifold heat exchanger bolt holes are the give away. The A intake port spacing is sumpin like 1/16” wider than a T too
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Tue Sep 28, 2021 8:52 pm
Thank you !
I think it’s a possibility for a speedster. ;)
Post by Scott_Conger » Tue Sep 28, 2021 9:25 pm
it is one of a 2 piece system (exhaust manifold) for a Swan Carb. That one is not for a T. I have one in my collection because it is quite unusual. Little info about them other than their battles with several car manufacturers over patent infringements
A little info and a couple pix here: http://www.mtfca.com/discus/messages/118802/123671.html
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Wed Sep 29, 2021 9:46 am
Scott, I think I have the exhaust manifold too.
It has a piece broke off of one of the ports.
I see the carb mounting holes are 90deg from the T manifold....thanks for the link.
