KR Wilson Tool ID help
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Wed Sep 29, 2021 4:08 pm
Digging through an estate collection of Model T parts and came across this KR Wilson fixture. I think it is for checking connecting rods. It has a number A335 cast in it.
Am I correct?
Is it for T rods?
Last Name: Hatch
Re: KR Wilson Tool ID help
Post by Dan Hatch » Wed Sep 29, 2021 4:43 pm
Any KRW tool with any A number is usually for an A . Go to the K R Wilson the oil page and you can probably find it. Dan
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Wed Sep 29, 2021 5:00 pm
What is the diameter of the shaft?
Post by speedytinc » Wed Sep 29, 2021 5:04 pm
Will work on T rods with a smaller dia mandrel. The important test gauge piece is not shown. Heavily rusted plate surface is no bueno.
Post by Scott_Conger » Wed Sep 29, 2021 5:44 pm
The missing piece is called a "Sea Lion".
Post by Allan » Wed Sep 29, 2021 8:23 pm
The sea lion is descriptive of the appearance of the gauge piece used on a number of rod alignment tools. However, a mate has a complete KR Wilson set-up, and the missing piece here looks nothing like a sea lion. Rather, it has four arms and at the end of each is a small stud/pointer which become the indicators that show mis-alignment.
These tools have round bars onto which the big end of the rod fits. You need multiple bars for different sized rod bearings to be able to use the fixture with accuracy. A better solution is to have one end of the bar milled into a square. Then, with the bar set with one of the flats on the horizontal, any number of different rods of different sizes an be checked. My more modern fixture came with just three interchangeable square fittings, and these allow rods from T models to large tractors to be checked on the one fixture. My engine shop gave me their small square because they have never had a use for it, nothing modern being as small as a T bearing.
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Wed Sep 29, 2021 9:00 pm
Thanks everyone for your help. I did some research online and found this page from a KR Wilson catalog. Looks like it is for Model T, A, and Fordson rods.
If anyone is interested. I’ll be bringing it to Hershey.
Post by Scott_Conger » Wed Sep 29, 2021 10:19 pm
This is what a Sea Lion looks like, close up: http://www.mtfca.com/discus/messages/70 ... 1511643730
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Wed Sep 29, 2021 10:34 pm
Thank you Scott!
