Correction Collapsed carburetor float
LesAlderson
First Name: Les
Last Name: Alderson
* REQUIRED* Type and Year of Model Ts owned: 1925 TT
Post by LesAlderson » Fri Oct 01, 2021 4:24 pm
Anyone seen a collapsed carburetor float and if so what the cause might be.
This is a Holly G on a 1925 TT.
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Melted carburetor float
Post by Rich Bingham » Fri Oct 01, 2021 4:38 pm
Can you identify the float material ? If it's some kind of synthetic (plastic) it would be a latter-day replacement that has succumbed either to an unusual amount of heat or perhaps elements in the ever-changing brew that gasoline has become in recent years. The original floats were either cork or brass.
FWIW, the Holley G, introduced in 1914, was phased out by 1921 I believe. (careful archivists will inform us correctly). The Holley G is a fine carb that will work well on most any year T or TT, and replacement floats are readily available from T parts suppliers.
"Get a horse !"
LesAlderson
First Name: Les
Last Name: Alderson
Post by LesAlderson » Fri Oct 01, 2021 5:04 pm
Upon further examination, it is a plastic, hollow float that has collapsed.
It does not appear to have gas inside the float.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Fri Oct 01, 2021 5:31 pm
3D printers aren’t practical for everything….,
