Installing a hand wiper
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Post by Nunsio1 » Sat Oct 02, 2021 5:37 pm
Thinking about installing a hand wiper, already have the hole in the upper windshield frame. Is it worth the bother.. how’s the quality and fit of the repop parts available. Thanks for any opinion’s
John
Oscoda Michigan
Re: Installing a hand wiper
Post by Mark Gregush » Sat Oct 02, 2021 5:40 pm
They are ok. You may have to add a sleeve to the hole, depending on how the shaft fits through it.
rickg
Last Name: Goelz
* REQUIRED* Type and Year of Model Ts owned: 1924 Fordor, 1926 Coupe, 1923 popcorn Truck
Post by rickg » Sat Oct 02, 2021 5:53 pm
The wipers are different for the closed and open cars, i have closed cars so i have sent a couple back as they are for open cars.
Rick
Post by Norman Kling » Sat Oct 02, 2021 6:01 pm
They work very well, however, the blade does not last 20 years! We very seldom drive our T's in the rain, and since it rarely rains in the late spring, summer or early fall, it is only by chance that we might get caught in the rain here. And in winter when it does rain, we just don't tour on rainy days. Also you might find a rattle. I tie a cord around the windshield post and hook it over the handle to keep the wiper in place when not in use.
Post by Allan » Sat Oct 02, 2021 10:09 pm
When they drilled the hole through Henrietta's windscreen frame it was not square with the screen, so the wiper did not contact the glass as it should. That is where a sleeve comes in handy. I made a brass one to fit and soldered it in place so the rusty patina on the original screen frame was least disturbed. A small spring around the shaft on the inside of the car keeps gentle pressure on the blade.
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Sat Sep 24, 2022 1:35 pm
Be sure to somehow use 2 jam nuts, or lock tite or peen over the bolt. Model T vibrations and just using the wiper will sometimes cause the nut to loosen and fall off
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
