Model T aluminum locking steering wheel
Tmodelt
Topic author - Posts: 167
- First Name: Kim
- Last Name: Wynn
- * REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
All thoughts / ideas welcome. The aluminum spider has been painted white with what looks like house paint. The rim will be replaced. What would be the easiest / fastest way to remove this paint without affecting the locking mechanism? I don't plan on polishing. Thanks
- First Name: Henry
- Last Name: Lee
Re: Model T aluminum locking steering wheel
Kim if you have a turkey fryer and a large pot with hot water does an amazing job!
Tmodelt
- First Name: Kim
- Last Name: Wynn
Should I turn the heat on under the fryer to keep water hot? Just got 2 new keys cut. The locksmith made sure lock and key worked.
