Info Wanted RUSHMORE SEARCHLIGHT
Professor Fate
Last Name: S
Post by Professor Fate » Sun Oct 10, 2021 6:19 pm
Anyone know anything about the RUSHMORE SEARCHLIGHT? Used on cars? Model T's??
________________
**FATE**
Last Name: Seth
Re: Info Wanted RUSHMORE SEARCHLIGHT
Post by perry kete » Sun Oct 10, 2021 9:25 pm
Professor Fate, If you would look at the center of you car hood you would see the light in question
Professor Fate
Last Name: S
Post by Professor Fate » Sun Oct 10, 2021 9:45 pm
"Yes!!"
20210918_104823 (1) (1).jpg (10.31 KiB) Viewed 2326 times
________________
**FATE**
ahovey
First Name: Austin
Last Name: Hovey
* REQUIRED* Type and Year of Model Ts owned: ‘11 Torpedo
Board Member Since: 2014
Post by ahovey » Sun Oct 10, 2021 10:06 pm
Correct me if I am wrong but I don’t believe they were ever supplied on Model Ts out of the factory.
I have seen them on quite a few different brass cars, often luxury marques. At least on some Pierce Arrow’s I have seen them with plano convex lenses. The lense is flat on one side and convex on the outer side to help throw the light. Often the lense is made up of multiple piece of glass ~2” wide vertical pieces.
Post by TRDxB2 » Mon Oct 11, 2021 2:30 am
Google this - Rushmore Dynamo Works - lots of info
Post by TRDxB2 » Mon Oct 11, 2021 2:32 am
And there was a copy cat
Professor Fate
Last Name: S
Post by Professor Fate » Mon Oct 11, 2021 8:28 am
I found the light housing at a local flea Mkt yesterday. Cracked mirror and glass. No shaped lense glass as you mention. Mounting bracket was missing. Asking price $80. I'm tempted to run and grab it this a.m.
________________
**FATE**
pre15dale
First Name: Dale
Last Name: Kemmerer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Post by pre15dale » Mon Oct 11, 2021 11:50 am
That one is actually a head light. I can tell by the mounting bracket . All rushmores said search light on the chimney whether headlight or an actual search light. The search light model mount was made to swivel up and down and also had handle on the back. $80 Is a pretty good buy for one in that nice condition.
