Is there adjustment to fix this?
Myxr6turbo
First Name: Shawn
Last Name: Barnard
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Post by Myxr6turbo » Mon Oct 11, 2021 12:40 am
I have just pulled the engine apart. I never turned it over when I got the car as u didn't know the condition of the engine. I have pulled the pistons out and when I rotate the crankshaft the camshaft seems to touch the bearings. What do I need to do to adjust the backlash if that's what the problem is?
Here is a video of it.
https://youtu.be/v0MG9vImzPA
Any help would be much appreciated.
Regards.
Shawn
Re: Is there adjustment to fix this?
Post by Norman Kling » Mon Oct 11, 2021 1:07 am
If that is really the camshaft touching the bearings, your main bearings are way out of line or you have the wrong crankshaft.
Can't sure from the pictures. Could be a noise in the timing gears right at that moment?
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Post by Myxr6turbo » Mon Oct 11, 2021 1:43 am
If you watch the video closely you can see the lobe touch the bearing and the bearing moves towards the gear.
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Post by Myxr6turbo » Mon Oct 11, 2021 2:02 am
Here is a longer more detailed look.
https://youtu.be/mlP4IPp6CB8
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Oct 11, 2021 2:07 am
That's an early cam that needs the long front bearing with the notch in it. There are two different front bearings and they are not interchangeable.
