Valve Spring Seat Diameter
mortier
First Name: Philip
Last Name: Jamison
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Post by mortier » Sun Mar 24, 2019 12:17 pm
Could some tell me the Model T Valve Spring Seat diameter?
Phil
Re: Valve Spring Seat Diameter
Post by Mark Gregush » Sun Mar 24, 2019 1:08 pm
Outer 1.125 inner 1.025 approx. Material approx .035 thick
The is from a used one so may have some wear. The inner would just be larger then the spring diameter.
mortier
First Name: Philip
Last Name: Jamison
Post by mortier » Sun Mar 24, 2019 7:53 pm
Thanks. I'm hoping it will fit my 1915 Overland.
Phil
Post by Mark Gregush » Sun Mar 24, 2019 8:04 pm
Another choice might be Chevrolet. Up to 1928 at least they used a flattened cotter pin type pin. So the seat would work somewhat the same as Ford and would be a little larger. I will check the diameter of the spring later today and post the info.
Post by Mark Gregush » Sun Mar 24, 2019 9:49 pm
The Chevrolet (1928) springs are approx. 1.200 in diameter. Subtract about 3/16 for the inside diameter. The other difference is the Chevrolet keepers don't have an outer rim, like the Ford ones. If you look close at the photos in the link you can see them.
http://my28chev.blogspot.com/2012/06/19 ... -rust.html
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Mar 24, 2019 10:19 pm
Phillip if you need the 1928 Chevy ones I have plenty of serviceable ones.
All the Best,
