oil for model t
fordgood1
Topic author - Posts: 38
- First Name: Stephen
- Last Name: Francois, Jr
- * REQUIRED* Type and Year of Model Ts owned: 1924 t Touring, 1924 T Tudor Sedan, 1915 T Roadster
oil for model t
Can I use Valvoline 10/30 oil in my 1924 Model T?
Mindless Automaton
- First Name: Kep
- Last Name: Kerensky
- * REQUIRED* Type and Year of Model Ts owned: 23 truck, 26 bug
- Board Member Since: 2011
Re: oil for model t
Yes. I've used it myself.
Re: oil for model t
Yes.
A link on this page will tell you all abut it. http://dauntlessgeezer.com/DG103.html
- Last Name: Hjortnaes
Re: oil for model t
I use 5W/30 or 10W/30. Whatever is cheapest that day.
Jeff Hood
- First Name: Jeff
- Last Name: Hood
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
Re: oil for model t
Any oil you can get today is WAY better than any oil available in Model T times.
Re: oil for model t
Go to the nearest Dollar store, Walmart or Autozone any buy their house brand oil. 5w or 10w30 is fine. No need to buy any super duper exotic or big name brand oil for a Model T.
It’s better oil than Henry ever envisioned for a Model T.
Joss
- First Name: Joss
- Last Name: Sanderson
Re: oil for model t
There are two important things with oil.
Keep it full. Change it often.
Oil is cheap. An engine rebuild is not.
Jugster
- First Name: Bob
- Last Name: Coiro
- Board Member Since: 2009
Re: oil for model t
Some Model T Fords have a tendency to creep immediately after starting. For obvious reasons, this can be especially disconcerting when hand-cranking. My Flivver stopped that habit when I switched to 5W30 oil. It's just a little more slippery when cold then 10
W30 and that seems to reduce or eliminate the starting-creep.
