The Most Complicated Gas Line You Will Ever See On A Model T (Final Update)
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Wed Oct 13, 2021 6:10 pm
This ‘25 Coupe had a total restoration 20 years ago. I have no idea what they were thinking. Getting the Carburetor off to clean out was a huge PIA. I will be replacing with a regular potato and one piece line. Enjoy!
Last edited by MichaelPawelek on Sat Oct 16, 2021 7:39 pm, edited 1 time in total.
Dave Sullivan
First Name: David
Last Name: Sullivan
* REQUIRED* Type and Year of Model Ts owned: 1923
Re: The Most Complicated Gas Line You Will Ever See On A Model T
Post by Dave Sullivan » Wed Oct 13, 2021 6:25 pm
Must have had stock in Imperial Brass..dave
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Wed Oct 13, 2021 6:37 pm
The problem is that someone started at the tank and made all the runs and 90° bends to the carburetor not taking into consideration the carburetor would ever have to be taken off in the future. It is very stiff and precise but with no “Union” in the line.
Post by speedytinc » Wed Oct 13, 2021 6:48 pm
I am seeing 3 "union/couplings". Looks like a mess of compression ring fittings.
Someone had a can full of brass fittings needing a purpose.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Wed Oct 13, 2021 6:56 pm
The two near the carburetor actually have threads on the back sides and tighten up as you try to unthread them. I’ve never seen this type of fittings before.
sweet23
First Name: Darryl
Last Name: Bobzin
Post by sweet23 » Wed Oct 13, 2021 7:57 pm
When non mechanically incline people betterize things. I see it every day.
Last Name: Hjortnaes
Post by DHort » Wed Oct 13, 2021 10:01 pm
Probably worked at a hardware store.
Post by Mark Gregush » Thu Oct 14, 2021 1:51 pm
I saw a 1926/27 setup on Facebook (can't find the picture now), that had all kinds of twist, turns, dogleg and filter(s). They, too, took something so simple and over complicated it!
Last Name: Seth
Post by perry kete » Thu Oct 14, 2021 2:06 pm
Perhaps his uncle was a plumber!
John Codman
Last Name: Codman
Post by John Codman » Fri Oct 15, 2021 10:07 am
Rube Goldberg is alive and well.
Post by TXGOAT2 » Fri Oct 15, 2021 10:08 am
But... the installation is not complete!! It needs magnets and clothespins if it is ever to function properly... filters, filters, filters.... and where are the fuel pumps??
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Fri Oct 15, 2021 10:41 am
Funny you should mention clothes pins. Most folks under 50 wouldn’t know what they are. I still have a shoe box full I occasionally use to hold small parts and hang things on the wall. Also to hold gaskets in place as I Permatex them up. Save any old ones you have. Like everything else the newer ones are stupid worthless.
Post by TXGOAT2 » Fri Oct 15, 2021 10:47 am
I came across a website of someone who is making real clothespins that actually hold together and work. I can't recall how to access it. Some searching might turn it up, if it still exists.
Post by Norman Kling » Fri Oct 15, 2021 10:53 am
He probably had to take it off very often! There is no sediment bulb and I didn't see anything like a filter in the line. Lots of joints which could catch sediment though.
John Codman
Last Name: Codman
Post by John Codman » Fri Oct 15, 2021 5:20 pm
I have some that I actually use to pin clothes to a clothesline. The clothesline uses no electricity, and is (in the SW Florida sun) just about as fast as a clothesdryer.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Fri Oct 15, 2021 5:49 pm
Hey - It Works!
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Fri Oct 15, 2021 6:05 pm
I’ve seen several that look exactly like that. Every T I’ve bought in the past had similar” improvements” added to them in the past. I promptly remove them unless it’s a working era manufactured accessory. Otherwise it’s back to stock in order to make future troubleshooting easier.
Post by TXGOAT2 » Fri Oct 15, 2021 7:25 pm
If you add a fuel pump or two you can then add a fuel pressure regulator.... maybe do a 2 stage setup with a high and low pressure pump and 2 regulators!
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Fri Oct 15, 2021 8:01 pm
Well, The ground up rebuild on this Model T was done 21 years ago by someone in San Diego so I can take no credit for all this added mess! 😊
Post by Wayne Sheldon » Fri Oct 15, 2021 9:47 pm
I am not sure which would be worse? That mess? Or four feet of rubber hose cobbled in?
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: The Most Complicated Gas Line You Will Ever See On A Model T (Final Update)
Post by MichaelPawelek » Sat Oct 16, 2021 7:44 pm
Dismantled the “improved” gas line someone installed 21 years ago and went back to original. 26 parts back to 6 parts! 😊
Post by TXGOAT2 » Sat Oct 16, 2021 7:56 pm
Henry would approve.
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
Post by FreighTer Jim » Sun Oct 17, 2021 9:14 am
Hi Michael 👋
Looks Good !
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
