Glass tape
Myxr6turbo
First Name: Shawn
Last Name: Barnard
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Glass tape
Post by Myxr6turbo » Thu Oct 14, 2021 5:10 am
Has onyone found an online store that sells the glass tape at a reasonable price and will ship to Australia? I just can't afford a new magneto at the moment on top of everything else.
Thanks guys.
Shawn
Re: Glass tape
Post by Mark Gregush » Thu Oct 14, 2021 1:46 pm
Might start by doing a search "mtfca rebuilding magneto" There have been recent post that should have companies and suggestions for getting the tape.
Also so, edit your title. When I saw it, was thinking glass setting tape, not wrapping the coils on the magneto. That should help get more views. Click on the pencil, that will open the edit window.
Quickm007
First Name: Mario
Last Name: Brossard
Re: Glass tape
Post by Quickm007 » Thu Oct 14, 2021 9:43 pm
I don’t know how much your tape is broken? If it’s some magneto, you could use transparent epoxy as well. I did Personally To fixe an issue with 2 round magneto and it’s work properly.
Super Mario Bross ;)
1911 Touring
1914 Speedster
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Re: Glass tape
Post by Myxr6turbo » Thu Oct 14, 2021 10:40 pm
It's pretty bad. I don't think I would trust it.
Re: Glass tape
Post by TRDxB2 » Thu Oct 14, 2021 11:02 pm
I did a search on Scotch 27 tape in AU and found a supplier of Glass Tape in AU. However , their web site may have an issue so contact via email sales@embossingtapesupplies.com.au
ETS
Miranda NSW 2228 Australia.
Telephone: (02) 9526 2055
Facsimile: (02) 9524 7371
Poppie
First Name: Neil
Last Name: Martin
* REQUIRED* Type and Year of Model Ts owned: 11 tourer 18 tourer 18 TT
Re: Glass tape
Post by Poppie » Fri Oct 15, 2021 7:01 pm
Shawn,
You don't need glass tape for bobbin plate repairs, I have repaired many > 30 volt AC Model T bobbin plates and rewound and taped thousands of >240 volt AC coils using linen tape. The important item is the insulating varnish used to secure the coils from vibrating. Where are you in VIC ? Send it over the boarder and I will fix it for you ......n
