Factory magneto charge
Post by John kuehn » Thu Oct 14, 2021 2:01 pm
Recharging a T magneto as always intrigued me. There have been several posts over the years on the subject and as for me I charged the magnets out of the car when I rebuilt the engines.
With that being said how often did the Ford service centers have to do a recharge during the Model T era and T’s were driven all the time or did they do it at all. They must have had a method to do it in cars that weren’t damaged but simply weren’t working on mag and needed the magnets to be recharged.
The Ford service manual says to have the magnets removed and a new set installed. Was that the only way the problem was solved and not any other way besides doing an engine tare down? I was thinking Murray Fahnstock had something published about using batteries outside the car to do it.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Re: Factory magneto charge
Post by Will_Vanderburg » Thu Oct 14, 2021 2:14 pm
There was a device available back in the day that would recharge the magnets in the car. It plugs into a regular wall electrical socket.
Unless he sold it, a friend of mine has one.
William L Vanderburg
1922 Center Door Sedan
Post by John kuehn » Thu Oct 14, 2021 2:19 pm
I would bet that would sell if someone would copy it. I would think there would be a way to do it without going to a lot of trouble using the battery or welder method. I thought somebody came up with a home made DC charger that was fairly easy to use.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Thu Oct 14, 2021 2:45 pm
Ford Service mechanics used a KRW Battery Charger to charge the magnets in the car. A magnet charger was included in the battery charger unit, and you changed a fuse in the unit to power the charger. A 110 volt battery charger used a 60 amp fuse while a 220 volt battery charger used a 30 amp fuse.
It used a separate indicator placed on the mag post to determine the magnet's polarity.
This information is in Volume 7 of the Ford Service Bulletins from 1926, starting on page 98
In volume 5 of the bulletins, Ford recommended NOT to use any devices on the market to recharge the magnets and that volume was published in 1924
Post by John kuehn » Thu Oct 14, 2021 3:03 pm
Maybe Ford was trying to corner the market so to speak! But like most any of the aftermarket products that were sold for Model T’s a guy would have to make a profit to make a magnet in car charger. Evidently aftermarket brakes was something that was successful and they are till this day.
The KRW Charger you mentioned would be a prized Ford shop item like a pan straightening jig is when you find one. I’ll bet somebody has a Ford shop charger you mentioned.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Thu Oct 14, 2021 3:12 pm
That same Volume 7 from 1926 DOES specify that in car charging using the Battery Charger with magnet charger ability, necessitates rotating the flywheel 1/4 turn and charging again for a total of 4 turns to complete one revolution. (charging 4 magnets with every quarter turn.)
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Fri Oct 15, 2021 12:18 pm
The only reason I have found or suspected for that four turn charge is the magnets are sometimes closer to the coil pickups at the bottom.
The closer they are, the stronger charge is that will be applied.
Last Name: van Ekeren
Post by Kerry » Fri Oct 15, 2021 4:50 pm
I've come across cracked bobbin plates in engine re-builds over the years, the only reason I can think of why would be from in car mag charge.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Sun Oct 17, 2021 5:06 pm
Someone have picture of that device perhaps?
Super Mario Bross ;)
1911 Touring
1914 Speedster
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Oct 17, 2021 5:32 pm
15 years ago when I made 4 of the original type all nice pretty with vintage labels and clips.., I sold two at $350.00 each but had $400.00 each in them. Junked that idea.., no one will spend the money. All gone now!
Post by John kuehn » Sun Oct 17, 2021 5:35 pm
There is a guy on the earlier thread about trying to charge a magneto with a DC welder who recharged his mag in the car with a heavy duty floor 12 volt battery charger with a ‘boost’ or as some call it a ‘ quick start’ feature. It recharged his mag. That’s sounds essentially the same as what the Ford shop battery charger was doing. He used the ground cable to the frame and then flashed the positive cable to the mag post. Interesting!!
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Sun Oct 17, 2021 8:18 pm
Next time I’m over at his place, I’ll see if he still has it
jab35
Last Name: Bartsch
Post by jab35 » Sun Oct 17, 2021 10:14 pm
Post by RajoRacer » Sun Oct 17, 2021 10:55 pm
Or a Stahl Magfixer ??? I'll take a photo of mine tomorrow.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Mon Oct 18, 2021 10:06 am
Hi Steve, did you try that tool ? It is working well with modern battery of 12 volts? please share your own experience
1911 Touring
1914 Speedster
JRSpada4
First Name: Jim
Last Name: Spadafore
* REQUIRED* Type and Year of Model Ts owned: 1925 Touring
Post by JRSpada4 » Mon Oct 18, 2021 10:07 am
The October 15, 1926 Service Bulletin shows the battery charger being used to recharge magnets in-car. You’ll find the process starting on page 97 of this pdf.
http://www.cimorelli.com/mtdl/service_b ... sb1926.pdf
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Oct 18, 2021 10:40 am
Yes, it’s a rectifier
jab35
Last Name: Bartsch
Post by jab35 » Mon Oct 18, 2021 11:20 am
That's a great article. I like the part relating to fuse capacity needed to power the magneto charger. Essentially 'replace normal fuses' with large capacity 60A fuses inside the charger as well as the AC line in the shop. I wonder how many of the 'special fuses' were left in place leading to electrical fires from overloaded circuits.
Post by TXGOAT2 » Mon Oct 18, 2021 11:31 am
A magneto charger that could provide pulsed DC at 3600 pulses/second with variable voltage and 80-90 available amps could be built to operate off a 12 Volt car battery.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Tue Oct 26, 2021 9:44 am
I would like to hear more about Stahl Magfixer. Experience people had with it.
1911 Touring
1914 Speedster
