Does anybody know which part number go to which set of nuts? There is no description of where those two part numbers go....other than a rather muddy picture of no particular scale.
Also were the screws that held the differential housings together lock wired also?
***1918-1822 Model TT Ruckstell Axle Differential Assembly**
VowellArt
Topic author - Posts: 584
- First Name: Martynn
- Last Name: Vowell
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring, th "Lady"
- Board Member Since: 2012
Fun never quits!
- First Name: Adrian
- Last Name: Whiteman
Re: ***1918-1822 Model TT Ruckstell Axle Differential Assembly**
Can't help with the numbers, but it is looking good!
The carrier for the 2 pinion shaft looks about right,
Cheers
Adrian
Cheers
Adrian
L.I. Tom
- First Name: Thomas
- Last Name: Pilz
- * REQUIRED* Type and Year of Model Ts owned: 1921 roadster, 1923 roadster pickup
On these truck axle's does both axles use the ball bearing or only the rux side (I don't have the book but the fella that owns it does but I haven't looked at it yet). I thought I saw a video a while back were the original passenger side used an original bearing and thrust washer. If so does anyone know if those thrust washers available anywhere? I will be going over one of these this winter. Thank you for creating these beautiful breakdowns.
Tom
Tom
VowellArt
- Last Name: Vowell
Tom, both sides have same Thrust Bearing P-1009.
Fun never quits!
L.I. Tom
- Last Name: Pilz
Thank you very much for the reply and the photo.
Tom
Tom
