Transmission clutch Gap tool
RGould1910
Last Name: Gould
Post by RGould1910 » Thu Oct 21, 2021 6:09 pm
The vendors are out of the gap tool I needed, so I tried using the correct size socket. It didn't work well so I made one out of stuff I had on hand. I decided to thread the plug and handle because my welding/brazing/soldering skills are marginal. I'm happy with the result.
Last Name: Wrenn
Re: Transmission clutch Gap tool
Post by TWrenn » Thu Oct 21, 2021 6:12 pm
Nice work. How's that saying..."necessity is the cause of invention" or something like that!
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Thu Oct 21, 2021 6:53 pm
At my house growing up, the saying was “necessity is a mother.” :lol:
Eric
Post by Allan » Thu Oct 21, 2021 7:23 pm
I don't have that kind of patience. Well done. I used a modern Ford wheel nut, 13/16" across the flats with a rod welded to it for a handle. I like the fact that the flats on the nut set the tool well, rather than having to organise it to sit at the correct angle in the gap.
Allan from down.
jab35
Last Name: Bartsch
Post by jab35 » Sat Oct 23, 2021 8:58 am
Nice project. Following on Alan's point, it seems making the gage like RGould's from 13/16" round stock and using the diameter of the cylinder as the gage would work too.
Post by Norman Kling » Sat Oct 23, 2021 10:42 am
I've never seen a tool like that. Looks like a very small mallet. Where and for what purpose is it used?
Post by RajoRacer » Sat Oct 23, 2021 11:00 am
It's used to set the distance between the driving plate and the clutch throw-out collar.
Post by TRDxB2 » Sat Oct 23, 2021 11:04 am
Used to adjust the clutch fingers http://www.mtfca.com/discus/messages/59 ... 1474933793
Clutch gap tool.png (661.91 KiB) Viewed 2748 times
Post by Norman Kling » Sat Oct 23, 2021 11:52 am
Thank you,
I learned something this morning.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Sat Oct 23, 2021 12:19 pm
I use this , Electric wire
Toon
