Parade seating 1914 Touring - Question
GJScholz
First Name: Gregory
Last Name: Scholz
Post by GJScholz » Mon Mar 25, 2019 6:01 pm
Gang,
For a parade, what are your thoughts on seating someone, (with the top down), on the raised back edge of the rear seat?
I'm kind of on the fence about it. It seem a bit unsafe to me.
I've got a line on a barbershop quartet that wants a ride.
What are your thoughts?
Thanks,
Greg
Greg Scholz
4th Generation Caretaker
1914 Ford Touring
Survivor Class
http://personal.gregscholz.com/
Esko MN
KD0UYN ‘73
Ruxstel24
Last Name: Hanlon
Re: Parade seating 1914 Touring - Question
Post by Ruxstel24 » Mon Mar 25, 2019 6:40 pm
In this day of age and liabilities, I wouldn't.
4 adults on the rear of the body might make for a good wheelie though !! :shock:
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Mar 25, 2019 7:38 pm
For a barbershop quartet, I'd put two in the backseat and one on each running board.
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Mon Mar 25, 2019 9:01 pm
I have a '14 Touring also and would not let anyone sit on the top of the back seat, even for a slow parade. If they fall off, you're in deep do do, and they might wreck your top also.
Keith
Post by Original Smith » Tue Mar 26, 2019 10:14 am
That part of the body isn't that strong anyhow. I'd be very cautious to do that, and the liability too.
Dan B
Last Name: Blaydon
Post by Dan B » Tue Mar 26, 2019 10:27 am
I agree with the others. This is not the same as when you see someone sitting on the top of a late model convertible with a big trunk.
If there’s not enough room in the car I would consider the running board as the next best option. Would be uncomfortable for a long parade though. It’s not very wide.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Tue Mar 26, 2019 10:32 am
If a barbershop quartet is going to entertain and sing in a parade, they should walk. Then they can saunter right up to the curb and serenade folks where they are standing and sitting.
Otherwise, one in the front seat, three in the back seat.
Last Name: Seth
Post by perry kete » Tue Mar 26, 2019 10:36 am
Depending on how wide they all are the 4 people should fit on the back seat without any issues (barber chair not included). Look at the many photos of Model T's with the top down you will see everyone is exposed from their shoulders up and very visible. I would suggest you meet with the group before you commit to driving them and put the top down and let them sit in it to see if it will work.
GJScholz
First Name: Gregory
Last Name: Scholz
Post by GJScholz » Tue Mar 26, 2019 10:38 am
Excellent.
Meeting with them beforehand, with the options of sitting 4 across, or seating two, with two on the running boards it is!
Thank you all for your ideas!
Thank you,
Greg
Greg Scholz
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
Post by Don D » Tue Mar 26, 2019 12:15 pm
Greg,
I would consider fabricating a box that could be set into place to replace the rear seat cushion. That box could raise the seating area equal in height with the top of the rear arm rests that extends wide enough to accommodate all four so they are raised up to be better seen and the extended sides over so the arm rest as well an the rear seat base both support the musicians. If you decide to make a box PLEASE be sure to sand or cover all sharp edges so the seat backrest area does not get cut during its use.
Best of luck,
Dom
Post by Scott_Conger » Tue Mar 26, 2019 12:38 pm
I would think 4 guys in the back seat of a T will barely be able to breathe much less sing...and if they do, they might sound like they had been sucking helium
Frankly, in a survivor '14, I would not consider 4 in the back seat. That's 700+ lbs on the springs and frame of the seat. Not in any of my cars!
Dean Kiefer
First Name: Dean
Last Name: Kiefer
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1926 Snowmobile, 1926 Wrecker
Post by Dean Kiefer » Tue Mar 26, 2019 3:45 pm
Halfway thru the parade stop and have them switch from running board to the seat and seat to running board.
GJScholz
First Name: Gregory
Last Name: Scholz
Post by GJScholz » Wed Mar 27, 2019 9:42 am
Dom, The box idea may have some merit, I'll give it some thought.
Dean, There's a judges stand that we might be stopping in front of.
The plan is for them to sing a bit. I would think they could take different seats when finished.
Great ideas everyone.
Greg Scholz
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
