Question for the administrators
Topic author - Posts: 2921
- Last Name: Hjortnaes
Some posts get very long and the only way to refer to each post within that subject is the time it was posted. Is there any way that posts under one subject can be numbered sequentially so that one can refer back to an earlier post? Or refering back to the post Wayne wrote or Steve wrote, so you have to look for that persons name. It would be easier to refer to post #14. Thank you Chris or Jeff.
Re: Question for the administrators
If you click on the quotation mark, it will copy the whole post to your reply like I just did. But you can only do one at a time, can't do multiple quotas to a post. How ever, you can edit out the unneeded bits before hitting the submit button.DHort wrote: ↑Wed Nov 03, 2021 2:20 amSome posts get very long and the only way to refer to each post within that subject is the time it was posted. Is there any way that posts under one subject can be numbered sequentially so that one can refer back to an earlier post? Or refering back to the post Wayne wrote or Steve wrote, so you have to look for that persons name. It would be easier to refer to post #14. Thank you Chris or Jeff.
I would rather see them quote only the relevant part of a post, as I just did.
