Adjusting toe in
John L
Last Name: Leffler
* REQUIRED* Type and Year of Model Ts owned: 1923 Coupe, 1927 Touring
Adjusting toe in
Post by John L » Wed Nov 03, 2021 7:45 pm
Ok ; got my axle straight and ready to put it back together. What is the best way to adjust toe in ,toe out?
Last Name: Wrenn
Re: Adjusting toe in
Post by TWrenn » Wed Nov 03, 2021 7:48 pm
Sending you an email.
Post by Steve Jelf » Wed Nov 03, 2021 8:57 pm
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Wed Nov 03, 2021 10:49 pm
You really want to get it right? Sure you do and the best garage way I’ve found is to get 4 pieces of tin or galvanized about 4” square. Make 2 sandwiches of grease between 2 pieces and put one under each front tire so they slide easy. Nothing beats the accuracy you’ll get if those tires can move.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Thu Nov 04, 2021 3:44 am
I do it a little differed
Toon
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Thu Nov 04, 2021 5:30 am
Like the system … but white carpet in a garage housing a model T. Boy are you brave. 😀
RGould1910
Last Name: Gould
Post by RGould1910 » Thu Nov 04, 2021 8:46 am
Clever, Anthonie!
Post by speedytinc » Thu Nov 04, 2021 9:28 am
I believe your method or minor variations are the most accurate way to go.
Wheel center height front & back, mark tires.
I mark the tires front & roll back 1/2 revolution.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Thu Nov 04, 2021 9:48 am
Toon, I like your way. What measurement we need to have?
Super Mario Bross ;)
1911 Touring
1914 Speedster
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Thu Nov 04, 2021 10:05 am
I like to use magazines or catalogs for slip pads. Most model T Ford front ends are loose enough to use 1/4" of toe in.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Last Name: Wrenn
Post by TWrenn » Thu Nov 04, 2021 10:45 am
Pretty much how I do it and explained to him, but I use a clamped pair of yardsticks to guage the distance front and back, and have had excellent results. Much easier. Helps to have a lift also!
On my '13 I have zero toe in..really rolls nice. Other two cars are at the spec 1/4".
Post by Norman Kling » Thu Nov 04, 2021 11:10 am
I do it the way Tim does it. I adjust the drag link to the point where it is zero or just out in front from zero. Then I lengthen one rotation and tighten the clamp. It might not be right on, but is as close as you can get it without bending the spindle arm.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Thu Nov 04, 2021 12:38 pm
I agree with Anthony's method. If front linkage is in good condition, I recommend 1/32 to 1/4 inch toe in. Keep in mind that one turn on the tie rod changes the toe in by about .22 inches.
Art Mirtes
