Help with steam engine id?
Angmar
Last Name: Bailey
Post by Angmar » Fri Nov 05, 2021 4:13 pm
Wondering if any of you have good infromation on this engine and or where I can go to get more information on it.
thanks in advance.
Meant to put this in the off topic, not sure how to move it now.
Steam 1.jpg (105.96 KiB) Viewed 3853 times
Still crankin old iron
kevinf
First Name: Kevin
Last Name: Fielding
Re: Help with steam engine id?
Post by kevinf » Fri Nov 05, 2021 5:10 pm
Try Smokestack, and list it in the steam forum. You might get lucky, just be aware there were a lot of jobbers building engines, some with very limited production. Good luck, Kevin
kevinf
First Name: Kevin
Last Name: Fielding
Post by kevinf » Fri Nov 05, 2021 5:14 pm
Sorry you will need to go to www.oldengine.com, and then go to the smokestack forum.
Angmar
Last Name: Bailey
Post by Angmar » Sat Nov 06, 2021 1:22 pm
Thank you.
Post by TRDxB2 » Sat Nov 06, 2021 2:41 pm
Closest I could find. for "Vertical Steam Engine". There are many similar in shape but none with the same dual fly wheels. These were used in small locomotives, boats etc
RichardG
Last Name: Grzegorowicz
* REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
Post by RichardG » Sat Nov 06, 2021 9:39 pm
most likely what you have is a Kerwood, made for sears and many other outlets, the only way to find for sure is the casting numbers IF there are any,, i have owned several over the years, i have a picture taken of me 50 years ago at a show with one i saved, it ran a sausage grinder in a butcher shop,in the day not every one had electric wiring and motors to do the work but they had boilers, i will find the photo to show, that type engine was refered to as a bottle engine, depending on boiler pressure 4-6 hp,
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Sat Nov 06, 2021 11:13 pm
I have one that is similar in construction that is marked Climax.
Angmar
Last Name: Bailey
Post by Angmar » Sun Nov 07, 2021 9:40 pm
a few more photos. Thanks for the help guys.
Steam 4.jpg (50.4 KiB) Viewed 3390 times
steam 3.jpg (72.83 KiB) Viewed 3390 times
steam 2.jpg (68.75 KiB) Viewed 3390 times
Post by TRDxB2 » Mon Nov 08, 2021 1:18 am
it would help to know what this says...
??canton Pump C0. A20?? Canton Ohio
pump 4.png (364.89 KiB) Viewed 3364 times
kevinf
First Name: Kevin
Last Name: Fielding
Post by kevinf » Mon Nov 08, 2021 6:37 pm
That last photo is of a duplex pump
Steam cylinders on one side and the pump cylinders on the other. Used as a boiler feed pump.
