Floorboards
BLB27
First Name: Bruce
Last Name: Brakke
Floorboards
Post by BLB27 » Fri Nov 05, 2021 8:07 pm
What coating/paint should I use on my new floorboards? Were the factory boards painted?
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Floorboards
Post by BE_ZERO_BE » Fri Nov 05, 2021 8:19 pm
I used Por-15 on my floorboards.
It adhears really well and wears like iron.
It has a glossy finish.
Unless you park outside, with the top down, in the sun, full time,
there are no issues with the color becoming cloudy.
Respectfully Submitted,
Be_Zero_Be
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Floorboards
Post by Humblej » Fri Nov 05, 2021 8:25 pm
26-27 floor boards were painted black at the factory, what particular black paint is up to you. I had good results with water based enamel from Home Depot.
