Location of Grease Fittings on Ruckstell Shifter Housing…
MichaelPawelek
Topic author - Posts: 712
- First Name: Michael
- Last Name: Pawelek
Does anyone have a picture copy of the location where Stan Howe used to install the fittings? Thank you…..
MichaelPawelek
Re: Location of Grease Fittings on Ruckstell Shifter Housing…
http://www.mtfca.com/discus/messages/11 ... 1272701475
http://www.mtfca.com/discus/messages/50 ... 1233127236
http://www.mtfca.com/discus/messages/17 ... 1320429160
Dropacent
- Last Name: Morsher
It will not do much good except pump grease into the axle in the first pic. Look closely at stans pic, two fitting right there will do the trick. You can use little button fittings that you drive in a hole, very inconspicuous that way, and it delivers grease right where you want it.
I've been running Ruckstell's in all my cars for 60 years, and see no need for additional lubrication. However, mine are the earlier version.
Dropacent
Aye, there’s the rub, Larry HOWEVER! …………. Of course the early style doesn’t need extra lubrication. Stan had it correct.
