Placement of Small Bracket Under Oval Tank.
Topic author - Posts: 712
- First Name: Michael
- Last Name: Pawelek
- First Name: Miles
- Last Name: Bowen
Re: Placement of Small Bracket Under Oval Tank.
I removed these brackets from my ‘25 touring tank just yesterday for painting. The banana-shaped part was under the single-footed bracket. No such piece under the two-footed bracket. I can’t say for sure that it’s correct, just how mine was put together.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Yes - bracket under the single leg only.
- First Name: Kevin
- Last Name: Matthiesen
The loose bracket you ask about goes on the one bolt to frame side tank bracket under the gas tank.
- Last Name: Strange
- Board Member Since: 2013
I just looked under my 1924. Banana bracket on single leg only.
