Axle repair - Arcoona Tableland South Australia
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Mon Nov 22, 2021 3:26 am
Dr. Walker putting a new crown wheel on his car; a cog was chipped whilst crossing the 30 miles of ironstone boulders on the Arcoona tableland.
https://collections.slsa.sa.gov.au/resource/B+53602
Re: Axle repair - Arcoona Tableland South Australia
Post by Wayne Sheldon » Mon Nov 22, 2021 5:27 am
Very interesting stuff!
Thank you for posting these wonderful views into life down under in the model T days.
Post by Allan » Mon Nov 22, 2021 7:48 am
The Arcoona Tablelands are in northern outback South Australia. That model T is a standard bodied Duncan and Fraser roadster. The registration number puts it in the early 1920's. like many Australian built bodies, it has a light fawn canvas top. These are even mentioned in Ford publications of the time, being referred to as Colonial tops.
Post by Allan » Mon Nov 22, 2021 7:58 am
I forgot to mention the two wooden boxes being utilised as axle supports. These are most likely fuel can boxes. Fuel delivered to country areas was packed in square, four gallon cans, and two such cans were packed into these boxes for transport. The boxes these days are highly collectable, some rarer ones bringing prices in the hundreds of dollars.
In the days, the boxes and the cans were utilised in many ways after the fuel was used. Stacked boxes were a common shelving item. An old milking shed on a friend's farm had walls clad with flattended out cans. The top and bottom of the can was removed and the tin flattened out. In is dairy, the flattened sheets were put through rollers to make corrugated sheets.
