New Warfords
tom_strickling
Topic author - Posts: 441
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
New Warfords
Is there a New KC Warford transmission for TT trucks ??
Their website shows only one product being made. Will it work on cars and trucks both?
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
Re: New Warfords
Like the original Warfords they were intended for truck use. Use in cars was secondary and probably occurs more today than back then.
Re: New Warfords
One consideration when putting a Warford in a passenger T is driveshaft length. Shortening the driveshaft will make the U joint run at more of an angle and will cause the wheelbase to change more with load changes. A TT, having a longer driveshaft, would be less affected. Advantages of the Warford include lack of shift linkage and no increase in unsprung weight.
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
- First Name: Henry
- Last Name: Lee
Re: New Warfords
Aluminum case Warford were for cars only! Under weight loads in the TT they would blow up. Cast iron were for TT but can be used in a car if the input shaft is shimmed or a auxiliary coupling is used. KC Warford’s can handle a TT as long as you do not haul 5 tons.
Hope this Helps,
Hope this Helps,
Dennis Prince
- First Name: Dennis
- Last Name: Prince
Re: New Warfords
For awhile they advertised a truck and speedster version, you might try calling Layne Machine Works, their ad is in the Vintage Ford.
Re: New Warfords
I believe the truck and speedster versions were only of differing ratios to suit the application. The fitting is the same for all.
Chris Haynes
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Re: New Warfords
Are they two or three speed?
Re: New Warfords
http://www.texastparts.com/mm5/merchant ... ory_Code=l
http://www.texastparts.com/mm5/manuals/WarfordTech.pdf
This chart shows red line, maybe could figure what red line would be for truck. Chances are you would never reach those RPMs anyway;
http://www.texastparts.com/mm5/manuals/ ... MChart.pdf
One390
- * REQUIRED* Type and Year of Model Ts owned: 25 TT
Re: New Warfords
Give them a call. I have one in my TT but have not put a ton of miles on it. (pun intended) basically under, straight through and overdrive. Those guys are great. Racers too I think.
