Replacing a Valve Part 3
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sat Mar 30, 2019 12:47 pm
Tore it back down, borrowed a friend's valve seat resurfacer and cleaned it up. The seat will eventually need replacing. But the car is not hard to start now, and grounding the plug does labor the engine, which it did not do after I replaced the valve last week.
Just finished taking it for a spin and it runs just like it did before the valve broke.
William L Vanderburg
1922 Center Door Sedan
Re: Replacing a Valve Part 3
Post by Scott_Conger » Sat Mar 30, 2019 12:51 pm
Good for you Will
