Need suggestion for oil leak in hogshead
Last Name: Hjortnaes
Post by DHort » Sun Mar 31, 2019 1:19 am
My T has developed some leaks and I would like to determine if it is mainly caused by the pedals in the hogshead. I think I will need to install seals in the hogshead, but that is down the road. What would you suggest I do to make a temporary fix? Thank you.
Re: Need suggestion for oil leak in hogshead
Post by Mark Gregush » Sun Mar 31, 2019 8:59 am
Give everything a good wipe down. Check your inspection cover and bendix cover. For now a drip pan under the car.
