Coil box nuts
Unprr
Last Name: Schmidt
* REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Coil box nuts
Post by Unprr » Sat Dec 25, 2021 5:07 pm
A few days ago, a discussion was started on how to prevent wire breaking. In the post was a photo of a coil box, with a different type of nut, being used.
My question is this, has anyone used these and how good do they hold and were do you find them.
George
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Re: Coil box nuts
Post by Jim Sims » Sat Dec 25, 2021 5:10 pm
the nuts are used to hold the termnal box cover on the Model A.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: Coil box nuts
Post by MichaelPawelek » Sat Dec 25, 2021 7:05 pm
Not for your application but your choice….😊
Re: Coil box nuts
Post by Steve Jelf » Sat Dec 25, 2021 7:54 pm
On my last trip I lost a couple of coil box nuts. I intend to install toothed washers. They will cost a lot less than the Model A nuts. :)
Re: Coil box nuts
Post by Allan » Sun Dec 26, 2021 5:30 am
Steve, when I build a coilbox I put a fibre washer on after the porcelain and then firm the nut up without crushing the porcelain. Then the wire terminal is fitted and the second nut. The key is a thinned down wrench to hold the inner nut so that it cannot move when the outer nut is done up. The outer nut becomes a locknut, so no star washer is needed.
Hope this helps,
Last Name: Juhl
Re: Coil box nuts
Post by Oldav8tor » Sun Dec 26, 2021 12:46 pm
Like Allen I use a fiber washer. To finish off I use a thin split washer over the wire terminal and a brass thumbnut. In 5300 miles I've never had one come loose.
Re: Coil box nuts
Post by Mark Gregush » Sun Dec 26, 2021 7:14 pm
I too use brass thumb nuts but without any washers on both the coil box and spark plugs. When the nut is almost tight, with the terminal a little to one side, I turn both the nut and terminal tight. Most of the time, they stay tight.
